Dainis
    248
About Dainis
839 profile views
  1. http://forums.xilinx.com/xlnx/board/messag...p;message.id=59 EDK 9.2i is curretnly scheduled to be released on 10/22/07.
  2. Такой вопрос поднимается каждый раз после выхода нового ISE .... :) Если только руками и через з.....
  3. Page 4 :) h_t_t_p://www.armkits.com/download/FlashProgrammer.pdf
  4. This software must be applied together with ARM emulator made by Embest or a JTAG cable made by yourself which we describe in our document.
  5. http://www.itee.uq.edu.au/~peters/xsvboard/stack/stack.pdf http://www.itee.uq.edu.au/~peters/xsvboard.../stackfiles.zip
  6. Вроди бы должно так работать ...
  7. http://w13.easy-share.com/1000907.html http://rapidshare.com/files/26230407/Bluet....0-DIGERATI.rar pwd:www.devilived.com
  8. ADS 1.2
    Я так и непоннал, где же баг ???
  9. ADS 1.2
    0x0000012c: e59f6058 X`.. LDR r6,0x18c ; грузим 0x01234567 0x00000130: e1a04000 .@.. MOV r4,r0 ; r0,r4 = dw 0x00000150: e1a00204 .... MOV r0,r4,LSL #4 ; ????????? r0=dw << 4 ; r4=0x12345678 r0=0x23456780 0x00000154: e1500226 &.P. CMP r0,r6,LSR #4 ; ????????? if (r6 == (r0 >> 4) ) ; if (r6 == 0x02345678) Просто используется оптимизация по возможностим ARM архитектуры.
  10. uCon is a nice replacement for HyperTerminal. It simplifies the interfacing to MicroMonitor over a serial connection. Plus it provides basic services typically used during embedded system development... TFTP client/server, DHCP server, serial command scripting, and even a terminal server that allows you to access the PC's serial port remotely via telnet. It is a major superset of HyperTerminal. Unfortunately, like HyperTerminal, it only runs on Windows. Simply unzip and execute (it is a self-installing executable). After startup, just click on the menu item Help->Overview for some basic information. If you're already a uCon user and are downloading an update, be sure to read the "What's New" help text after installation. http://www.microcross.com/ucon_install.zip
  11. 1) Должны бить кумулятивные. 2) EDK 8.1 будед работать толко c ISE8.1
  12. Чипи для передачи TDM ( E1, V.35) over Ethernet (IP) были у Redux ( now Resolute networks) и RAD.
  13. http://electronix.ru/forum/index.php?showtopic=16146 http://electronix.ru/forum/index.php?showtopic=23274 http://electronix.ru/forum/index.php?showtopic=480
