ser
55 -
0 ОбычныйИнформация о ser
Добрый день! Не удается запустить SFP модуль, ядро отказывается его включать. Если притянуть TX_DISABLE модуля к земле все работает. Процессор i.MX287, ядро 5.6.2. DTS: ahb@80080000 { mac0: ethernet@800f0000 { phy-mode = "rmii"; pinctrl-names = "default"; pinctrl-0 = <&mac0_pins_a>; phy-supply = <®_board_3v3>; phy-reset-gpios = <&gpio4 13 0>; phy-reset-duration = <100>; phy-handle = <ðphy0>; managed = "in-band-status"; status = "okay"; mdio { #address-cells = <1>; #size-cells = <0>; ethphy0: ethernet-phy@3 { compatible = "ethernet-phy-ieee802.3-c22"; reg = <3>; max-speed = <100>; }; ethphy1: ethernet-phy@1 { compatible = "ethernet-phy-ieee802.3-c22"; reg = <1>; max-speed = <100>; micrel,fiber-mode; sfp = <&fiber>; }; }; }; mac1: ethernet@800f4000 { phy-mode = "rmii"; pinctrl-names = "default"; pinctrl-0 = <&mac1_pins_a>; phy-supply = <®_board_3v3>; phy-handle = <ðphy1>; status = "okay"; }; }; fiber: fiber { compatible = "sff,sfp"; i2c-bus = <&i2c0>; los-gpios = <&gpio0 24 GPIO_ACTIVE_HIGH>; mod-def0-gpios = <&gpio0 6 GPIO_ACTIVE_LOW>; pinctrl-names = "default"; pinctrl-0 = <&sfp_pins_gpio>; tx-disable-gpios = <&gpio0 27 GPIO_ACTIVE_HIGH>; tx-fault-gpios = <&gpio0 4 GPIO_ACTIVE_HIGH>; }; лог ядра: . . [ 2.875500] libphy: SFP I2C Bus: probed [ 2.879840] sfp fiber: Host maximum power 1.0W [ 2.888324] libphy: Fixed MDIO Bus: probed [ 3.005492] libphy: fec_enet_mii_bus: probed [ 3.021072] i2c /dev entries driver . . [ 200.551606] Micrel KSZ8081 or KSZ8091 800f0000.ethernet-1:03: attached PHY driver [Micrel KSZ8081 or KSZ8091] (mii_bus:phy_addr=800f0000.ethernet-1:03, irq=POLL) [ 211.842321] Micrel KSZ8041 800f0000.ethernet-1:01: attached PHY driver [Micrel KSZ8041] (mii_bus:phy_addr=800f0000.ethernet-1:01, irq=POLL) при подключении SFP модуля [ 493.262941] sfp fiber: SM: enter empty:detached:down event tx_clear [ 493.269402] sfp fiber: SM: exit empty:detached:down [ 493.274492] sfp fiber: SM: enter empty:detached:down event insert [ 493.280751] sfp fiber: SM: exit probe:detached:down [ 493.602920] sfp fiber: SM: enter probe:detached:down event timeout [ 493.626051] sfp fiber: module D-Link DEM-220T rev C1 sn S9121H3000239 dc 170316 [ 493.635527] sfp fiber: SM: exit waitdev:detached:down [ 507.866207] sfp fiber: SM: enter waitdev:detached:down event los_low [ 507.872739] sfp fiber: SM: exit waitdev:detached:down [ 508.803644] fec 800f4000.ethernet eth1: Link is Up - 100Mbps/Half - flow control off отключение кабеля [ 2035.134718] sfp fiber: SM: enter waitdev:detached:down event los_high [ 2035.141430] sfp fiber: SM: exit waitdev:detached:down [ 2035.587365] fec 800f4000.ethernet eth1: Link is Down
Здравствуйте. Необходимо получить состояние порта GPIO1_24(вход), процессор IMX287, ядро Linux 3.16.1. поддержка sysfs интерфейса включена, в dtb файле прописано так: pinctrl@80018000 { pinctrl-names = "default"; bisy_pin_gpio1_24: bisy_pin_gpio1_24@0 { reg = <0>; fsl,pinmux-ids = < MX28_PAD_LCD_RD_E__GPIO_1_24 >; fsl,drive-strenght = MXS_DRIVE_4mA>; fsl,voltage = <MXS_VOLTAGE_HIGH>; fsl,pull-up = <MXS_PULL_DISABLE>; } что еще надо прописывать в DTB файле?
SMPTE 12M-1 (LTC)
ser опубликовал тема в Форумы по интерфейсам
Здравствуйте. Общее описание задачи. Прием сигнала LTC по SMPTE 12M-1, при этом прибор еще является разветвителем и имеет 3 выхода LTC. Вход и выход должны быть гальванически развязаны. Также прибор должен анализировать код и отображать его на дисплее. Вход и выход балансный. На данном этапе мало что понятно, информации кроме самого стандарта нет. Существуют ли готовые приемопередатчики этого сигнала? Или на чем они строятся? по стандарту: В найденной схеме светового пульта на входе SMPTE стоит LTC485, принять ей вроде как нормально, но для передачи ее уровень выходных напряжений велик. -
а я вот ничего холосего и класивого не вижу, если продолжить цитировать тот документ, что Вы начали: Цитата from Atmel AVR1020: Migration from ATxmega256A3/192A3/128A3/64A3 to ATxmega256A3U/192A3U/128A3U/64A3U т.к. программа писалась относительно давно, то немного подзабылось, что она еще и сама управляет этим передатчиком USART, соответственно когда я отключал USART на PD3 при конфигурировании, в остальной программе ничего не менялось... она так же выключала уже выключенный при конфигурировании UART, при этом даже если PD3 был сконфигурирован на выход он становился на вход, со всеми вытекающими... небольшая особенность a3u...
Проблема решена, все дело оказалось в маленьком различии USART A3 и A3U, ну и невнимательности конечно... XMEGA A MANUAL XMEGA AU MANUAL всем спасибо
собрано две платы макетных результат на обоих одинаковый, замыканий на землю и на соседние проводники нет, да и лог.1 на порту можно выставить PORTD_PIN3CTRL = PORT_INVEN_bm; но прямая запись в порт значения не работает имею ввиду если бы дефолтное значение влияло на работу то не работал бы еще один уарт например если же рассматривать структурную схему порта то выходная защелка отделена от элемента инвертирующего выход еще одним элементом на который приходит сигнал "OUT Override Enable" он видимо и не дает работать порту но модулей которые могут выйти на это пин всего два и оба отключены, да и структурная схема портов у 256a3 и 256a3u абсолютно одинаковая, как впринципе и основная часть даташита
да, по умолчанию все ремапы выключены но мне кажется что это проблема не модуля, по какой то причине не работает сам порт на который должен выйти усарт. различий REMAP регистр тоже не делает если бы он влиял половина бы не работала
к сожалению в даташитах не было найдено ответа на данный вопрос, адреса у регистров не менялись, модули атмел на данный порт не добавлял, на нем возможен выход двух модулей TCD0.OC0D и USARTD0, и это не объясняет почему не работает управление именно PD3, а остальные 50 выводов работают, в том числе и другие модули и без особенностей
Доброго времени суток! Возникла следующая проблема готовый проект написаный и отлаженный под xmega256a3 понадобилось перенести на xmega256a3u. При этом перестал работать USARTD0, используется только на выход, порт PD3. Отключив USART было выяснено, что прямое управление портом вообще не работает, он глухо в лог.0, единственное на что он реагирует это инвертирование выходного сигнала. Есть подозрение что это может быть из-за модуля USB, но он пока не нужен... В еррате вообще тишина, все документы атмела говорят, что просто записывайте проект даже без перекомпиляции под a3u и все должно работать, хотя и с перекомпиляцей не работает.
Выбор оперативной памяти
ser ответил ser тема в Работаем с ПЛИС, области применения, выбор
максимальное поддерживаемое разрешение 1600*1200(UXGA), один кадр при 24 битной записи это 46 Мбит, а при 32 битной записи 62 Мбита... удобнее я так думаю работать с 32 битной записью. информации на сколько можно раскочегарить Cyclone 3 я не нашел, есть только косвенная информация о плате Cyclone III FPGA Development Kit, на которой стоит DDR2 SDRAM и заявлено что она поддерживает разрешение UXGA и HDTV 1080p, и работает через память... на данном этапе сменить плис не проблема, главное понять, как все таки сделать лучше. плату расчитываю на 6 слоев, правда не знаю реально ли это впринципе для памяти DDR2... примеры разводки плат Altera пугают насчет преобразования частоты пока не решено, возможно она будет установлена константой 60Гц и прописана в EDID, а возможно входная 75 Гц допустим будет преобразовываться к 60 Гц, в настоящий момент думаю как проще, но с учетом на будущее -
DmitryR вы меня не правильно поняли, вопрос: относился к написанному далее: т.е. тактовая 200 МГц, а надо не менее 250 МГц, что влечет за собой смену семейства, подходят получается: - Arria II с тактовой 333Мгц - Stratix III с тактовой 400Мгц - Stratix IV, Stratix V с тактовой 400Мгц правильно я все понимаю? кто что порекомендует? обработка видео это конечно громко сказано, начальная задача выглядит так: 1. приняли сигнал допустим 1280*1024 2. разрезали на 4 части по 640*480 3. отправили на 4 выхода DVI/HDMI (пока не выбрано) как предполагаю чтение с памяти будет одновременным выводом, и специально резать на куски нет необходимости. -
не понимаю этот расчет... выбор плис был впринципе основан на Cyclone III FPGA Development Kit, BGA технология пока недоступна, поэтому был выбран TQFP корпус. причина по которой надо выбирать другую плис эта? на что тогда расчитан Cyclone III FPGA Development Kit, на котором установлено 256 MB DDR2 SDRAM?? -
ser опубликовал тема в Работаем с ПЛИС, области применения, выбор
Доброе время суток. Появилась задача принять и обработать видео сигнал. Источник сигнала вход DVI на микросхеме TI TFP401, обработкой предположительно будет заниматься Altera Cyclone III EP3C16Q240C8N. Максимальная частота видеоданных у TFP401 по даташиту 165 МГц, а надо еще успеть записать и прочитать. Вот и вопрос какой тип памяти лучше применить SRAM, SDRAM или DDR SDRAM с учетом сложности разводки платы и программной реализации. Опыта работы с ПЛИС особо нет. -
хочу прикрутить AVR ISP mkII к Eclipse, но avrdude не видит программатор... параметры запуска: avrdude -p x256a3 -c avrisp2 через некоторое время молчания появляется сообщение в чем может быть проблема? P.S. С AVRStudio все работает нормально.
EEPROM ATxmega256a3
ser ответил ser тема в MCS51, AVR, PIC, STM8, 8bit
это чтоб записать 2 байта в EEPROM надо городить такой огород? или попроще можно?
