GeorgK
Posts
67 -
Reputation
0 ОбычныйAbout GeorgK
Rank
- Birthday 07/27/1968
У меня OpenSDAD, когда генерит скрипт для Альтиума, формирующий посадочные места с элементами, делает так: // Форма прогрес-бара echo(str(cmd, "object progressDlg: TProgressBarForm", ProgFnameF)); echo(str(cmd, " Left = 800", ProgFname)); echo(str(cmd, " Top = 500", ProgFname)); echo(str(cmd, " Caption = 'Please wait...'", ProgFname)); echo(str(cmd, " ClientHeight = 80", ProgFname)); echo(str(cmd, " ClientWidth = 500", ProgFname)); echo(str(cmd, " Font.Height = -11", ProgFname)); echo(str(cmd, " Font.Name = 'Tahoma'", ProgFname)); echo(str(cmd, " Position = poDesktopCenter", ProgFname)); echo(str(cmd, " TextHeight = 13", ProgFname)); echo(str(cmd, " object statusLabel: TLabel", ProgFname)); echo(str(cmd, " Left = 10", ProgFname)); echo(str(cmd, " Top = 10", ProgFname)); echo(str(cmd, " Width = 480", ProgFname)); echo(str(cmd, " Height = 24", ProgFname)); echo(str(cmd, " Caption = 'Processing'", ProgFname)); echo(str(cmd, " Font.Height = -11", ProgFname)); echo(str(cmd, " Font.Name = 'Tahoma'", ProgFname)); echo(str(cmd, " ParentFont = False", ProgFname)); echo(str(cmd, " end", ProgFname)); echo(str(cmd, " object ProgressBar: TProgressBar", ProgFname)); echo(str(cmd, " Left = 10", ProgFname)); echo(str(cmd, " Top = 40", ProgFname)); echo(str(cmd, " Width = 480", ProgFname)); echo(str(cmd, " Height = 17", ProgFname)); echo(str(cmd, " end", ProgFname)); echo(str(cmd, "end", ProgFname)); // Скрипт-обработчик прогрес-бара echo(str(cmd, "unit ProgressBarDialog;", PrognameF)); echo(str(cmd, "interface", Progname)); echo(str(cmd, "type", Progname)); echo(str(cmd, "TProgressBarForm = class(TForm)", Progname)); echo(str(cmd, " ProgressBar : TProgressBar;", Progname)); echo(str(cmd, " statusLabel : TLabel;", Progname)); echo(str(cmd, "end;", Progname)); echo(str(cmd, "var", Progname)); echo(str(cmd, " progressDlg : TProgressBarForm;", Progname)); echo(str(cmd, "implementation", Progname)); echo(str(cmd, "procedure ProgressInit(aMax : Integer);", Progname)); echo(str(cmd, "begin", Progname)); echo(str(cmd, " progressDlg.ProgressBar.Max := aMax;", Progname)); echo(str(cmd, " progressDlg.ProgressBar.Position := 0;", Progname)); echo(str(cmd, " progressDlg.Show;", Progname)); echo(str(cmd, "end;", Progname)); echo(str(cmd, "procedure ProgressUpdate(aCaption : String);", Progname)); echo(str(cmd, "begin", Progname)); echo(str(cmd, " if progressDlg.ProgressBar.Position ", scrchar, "< progressDlg.ProgressBar.Max then", Progname)); echo(str(cmd, " begin", Progname)); echo(str(cmd, " progressDlg.statusLabel.Caption := aCaption;", Progname)); echo(str(cmd, " progressDlg.statusLabel.Visible := true;", Progname)); echo(str(cmd, " progressDlg.ProgressBar.Position := progressDlg.ProgressBar.Position + 1;", Progname)); echo(str(cmd, " progressDlg.Refresh;", Progname)); echo(str(cmd, " end;", Progname)); echo(str(cmd, "end;", Progname)); echo(str(cmd, "procedure ProgressFinish;", Progname)); echo(str(cmd, "begin", Progname)); echo(str(cmd, " progressDlg.Hide;", Progname)); echo(str(cmd, "end;", Progname)); echo(str(cmd, "end.", Progname)); Инициализация: // Инициалзация прогрес-бара echo(str(cmd, " ProgressInit(", elem_num, ");", Scriptname)); Изменение: echo(str(cmd, " ProgressUpdate('", cname, "');", Scriptname)); И соответственно окончание работы с баром - ProgressFinish;
Altium 21.6 и выше
GeorgK replied to Uladzimir's topic in Altium Designer, DXP, Protel
Большое спасибо за поддержку! Таки удалось решить эту проблему, теперь и пары создаются из любых механических слоёв, и видимость включается-выключается, и типы слоёв и пар назначаются. Проблема была в частности и в том, что Альтиум по своему усмотрению устанавливает тип переменных, иногда обращая внимание на объявление и ориентируясь на тип, передаваемый при первом присвоении. -
Altium 21.6 и выше
Речь идёт о присвоении значения элементу Layer переменной например типа IPCB_track или другого типа-наследника IPCB_Primitive. Найденные доступные методы требуют enum, например eMechanical10, и не принимают типы, обозначаеные Альтиумом как Dispatch/IDispatch. Проблему с созданием пар удалось решить методом CreatePairByKind (у IPCB_MechanicalLayerPairs), который не требует указания образующих пару слоёв. -
Altium 21.6 и выше
Здравствуйте! Не подскажет ли кто какой-нибудь способ скриптом размещать примитивы в механических слоях с 17 по 32? А то когда OpenScad создаёт файлы STEP и скрипт и он обрабатывается Альтиумом - всё нормально, в формируемой библиотеке стек слоёв создаётся, пары мех. слоёв назначаются и им присваиваются типы, примитивы переносятся куда надо, 3D модели приклеиваются - но кроме пар слоёв с номерами больше 16. Заранее спасибо за любые советы. -
Формат файла *.bin
GeorgK replied to inventor's topic in ARM, 32bit
Тут и думать нечего - добавить заголовок с размером, CRC, адресом загрузки, номером версии и т.д . Загрузчик проверит корректность заголовка, целостность тела, выведет в консоль результат проверки, а потом загрузит тело и передаст ему управление. -
Не ясно, где располагаются загрузчик с прошивкой (флеш NOR или NAND, флеш-диск и т.д.), т.е можно ли напрямую выполнять подпрограммы загрузчика из доступной области памяти или требуется копирование, разжатие, расшифровка и т.д. Можно собрать требуемые подпрограммы принципиально позиционно-независимыми и перемещаемыми, чтобы выдернуть их в ОЗУ, можно предусмотреть формирование в процессе сборки табличек для релокации (на основе соотв. сегмента из например ELF-файла, из которого формируется загрузчик - это зависит от используемой платформы, я делал такое для MIPS), которые используются для настройки подпрограмм после копирования в ОЗУ. Да, и достаточно ли будет ОЗУ для размещения в нём требуемого? Если же и загрузчик, и прошивка "прозрачно" читаются (то есть отображаются в адресное пространство) из флеша, достаточно предусмотреть формирование в известном месте списка адресов вызовов требуемых подпрограмм. По моему мнению, это "вкусная" задача для самостоятельной реализации, если же сроки поджимают, то да, согласен, целесообразнее искать готовое решение.
Возможен ещё вариант залоченных друг на друга синезубых приёмника и передатчика.
Как правильно принимать пакеты с ZMODEM
GeorgK replied to Alex_Golubev's topic in В помощь начинающему
Классическое описание протокола: http://gallium.inria.fr/~doligez/zmodem/zmodem.txt Пользовался им в те времена, когда ваял свою терминалку. -
Поляризованное реле РПС50. Как оно работает ?
GeorgK replied to kovigor's topic in В помощь начинающему
Были ещё поляризованные реле с двумя обмотками - одна на включение, другая на выключение. -
LWIP Socket API блокировка задачи
GeorgK replied to IvanPletnev's topic in ARM, 32bit
Возможно, что-то не так с платформенно-зависимыми настройками, завязанными на многопоточность, мьютексы, почтовые ящики? Состояние портов получал MIIшными запросами к "физике" коммутатора, проблемы были только в результате ошибок в самодельном переключателе контекстов и при слишком частом их переключении (около 100000 раз в секунду). А так HTTP, DNS, DHCP, Telnet, NetConsole нормально работали. Делал по примерами из документации к lwIP.- 8 replies
- socket api
- lwip
(and 1 more)
Tagged with:
uip стек, работа с несколькими соединениями
GeorgK replied to mantech's topic in Программирование
Кстати, в lwIP есть свой менеджер памяти - самостоятельно раздаёт память из выделенной области. Или это именно он глючный? Я-то с проблемами со стороны стека не сталкивался, возможно, из-за слишком щадящих условий. -
Вы совершенно правы, когда мне захотелось реализовать в загрузчике сетевую консоль (telnet, netconsole), именно по этой же причине пришлось переходить на lwIP - следующее поколение uIP и прикручивать многопоточность. -
Извиняюсь заранее, если это прописные истины. -
Там разве не по адресам-портам в том числе исходящим пакеты определяются? И по уникальному номеру соединения TCP. насколько помню, без проблем делал несколько "серверов" - DHCP, DNS, httpd. -
Поиск заранее известного сигнала в потоке
GeorgK replied to Bpovov's topic in Алгоритмы ЦОС (DSP)
Первое, что приходит на ум - согласованный фильтр. Тем более на ПЛИС хорошо параллелятся обработки с разным сдвигом фазы.
