Jump to content
smile
Свой
  • Content Count
    380
  • Joined
  • Last visited
Everything posted by smile
  1. https://www.macom.com/products/product-detail/MA4E1310
  2. What??? Buy this one http://www.ommic.com/produits/w2183g-65 or ask them, they will design after your specs.
  3. Make sure your diodes can handle this voltage.
  4. :bb-offtopic: Is it me, or your amplifier is potentially unstable around 3GHz?
  5. Add resistor(s) in series (or in parallel) to output (input, or both) of the transistor and I am sure you'll be able to match. Everything is possible. It is always a question of a trade-off. Theoretically speaking, simultaneous power matching at the input and at the output exists ONLY IF THE TRANSISTOR IS STABLE. Here is the book about this, read Chapter 3: rftoolbox.dtu.dk
  6. This one is quite broadband:http://ieeexplore.ieee.org/document/419866...98665&tag=1
  7. 1. Click on the graph (just to make it active). 2. Press Home/Copy (or just press Ctrl+C) 3. Paste in the text file. All the data will be there.
  8. It's quite broadband, but the noise figure is high and and linearity is poor. This indicates that the phase shifter is based on active devices (transistors). It should be possible to make it on discrete components. Theoretically - yes, but there is no information on switching speed in the datasheet. That would be the limit of your data rate.
  9. I would agree with soldat_shveyk, digital systems you would characterize by BER (bit error rate) instead of noise figure.
  10. Indeed, for circular waveguides you can get flanges without a single screw. Look at this transition for example: Can tell you from personal experience, they work perfectly, at least up to 300 GHz.
  11. No. I just don't want putin's troops in my country to "protect" me because I am russian, like it is in Crimea. :bb-offtopic:
  12. I was writing the same time as you. I did not see your post. As simple as that. Do you have hard time understanding my posts?
  13. For your evaluation board it says "VCC=V+=VPC=5.0V". So, connect VPC1, VPC2, and VPC3 to VCC (remember filtering parallel capacitors) That is too much. Your Amp gain is 37dB while P1dB= 33.5dBm. What is that?
  14. Hi, do you mean gate-drain capacitance? Look at Fig. 5.5 in this thesis.
  15. You are wrong! I do like decibels, and in your picture |S21|= -0.17dB > |S12|=-22.11dB. The same will be in linear scale, so it has nothing to do with decibels! Also wrong. A man with skills can always find a job with decent salary. Sharpen your skills instead of blaming the others. ;-)
  16. I would agree with freeport, this makes no sense! Can you show me an isolator with |S21|<|S12|?
  17. Maybe you right about isolators, but his statement I don't get. Do you mean |S21|>|S12| ? If we look at the mentioned MGA-565P8 at 5GHz |S21|=13dB while |S12|=-46.4dB which gives |S21|-|S12|=59.4dB, which is more or less typical number for amplifiers. The flatness of the characteristic is of course a different story, but it should be possible to find an amp with a good flatness in the range.
  18. Use a buffer amplifier between the oscillator and mixer! Amplifiers behave a lot like isolators, they let the signal to pass only in one direction. (just make sure the Amp can handle 100mW) ;)
  19. I don't really get that. "пин" you mean a via hole or a port? Sounds like there might be a problem with your model, or you simply forgot to include 0Hz point in MoM simulations. Also remember to define your via holes as via layer in the substrate definition. Built-in 3D viewer can help to debug your 3D model. Look at at your model in 3D and make sure that your vias look right and ports are defined between correct layers.
  20. Not really a reference, but a nice overview: http://mwrf.com/blog/5-new-things-do-single-chip-radar
  21. It's simple, just google "evanescent mode waveguide"
