Запись в память N бит (больше 16), чтение по 16 бит
собственно само описание (для простоты тестбенча использовал инициализацию блочной памяти)
library ieee;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity xxx is
       port (
    clk		  	   : in std_logic;
  rst		  	   : in std_logic;
  we           : in std_logic;
  din              : in std_logic_vector (127 downto 0);
  data_out         : out std_logic_vector (15 downto 0);
  memory_width_read         : in std_logic_vector (6 downto 0)
end xxx;
architecture rtl of xxx is
attribute ramstyle : string;
type srl_ram is array (127 downto 0) of std_logic_vector(127 downto 0);
signal ram : srl_ram :=  --(OTHERS => (OTHERS => '0'));
--57 bit
"000000000000000000000000000000000000000000000000000000000000000000000001111
11111111111111111111111111111111111111111111111111111",
"111111111111111111111111111111111111111111111111111111111111111111111110000
00000000000000000000000000000000000000000000000000000",
"111111111111111111111111111111111111111111111111111111111111111111111110110
00000000000000000000000000000000000000000000000000110",--64
--attribute ramstyle of ram : signal is "MLAB,no_rw_check";
constant mem_width_read_max_val : integer  := 128;
signal mem_width_read : integer range 0 to mem_width_read_max_val := 57;
signal cnt :  std_logic_vector (5 downto 0):= (OTHERS => '0');
--signal reg_mux, reg_reg_mux :  std_logic := '0';
signal reg_data_mem, reg_new, reg_old : STD_LOGIC_VECTOR(127 DOWNTO 0):= (OTHERS => '0');
signal addr_mem : STD_LOGIC_VECTOR(6 DOWNTO 0):= (OTHERS => '0');
signal bit_counter, bit_counter_reg : integer range 0 to 127 := 0;
signal slash_reg_data : STD_LOGIC_VECTOR (mem_width_read_max_val*2 DOWNTO 0 ):= (OTHERS => '0');
function prepare_bit_vector (reg_data_mem_v : std_logic_vector(127 downto 0); bit_vector_s : std_logic_vector(mem_width_read_max_val*2 DOWNTO 0 ); bit_quantity : integer range 0 to 16 ) return std_logic_vector is
variable result : std_logic_vector (mem_width_read_max_val*2 DOWNTO 0 ):= (OTHERS => '0');
variable reg_result : bit_vector (mem_width_read_max_val*2 DOWNTO 0 ):= (OTHERS => '0');
variable i : integer := 0;
begin
result(mem_width_read_max_val-1 downto 0) := reg_data_mem_v ( (mem_width_read_max_val - 1) downto 0) ;
reg_result := to_bitvector(result);
reg_result := reg_result sll bit_quantity;
result := to_stdlogicvector(reg_result);
--result(bit_quantity-1 downto 0) := bit_vector_s (15+bit_quantity downto 16);
i := 0;
while (i < bit_quantity) loop
	result(i) := bit_vector_s(16+i);
	i:=i+1;
end loop;
return result;
end function;
begin
    process (clk)
      begin
      if rising_edge(clk) then
         if we = '1' then
     ram(conv_integer(addr_mem)) <= din;
         end if;
    reg_data_mem <= ram(conv_integer(addr_mem));
     end if;
end process;
data_out <= slash_reg_data(15 downto 0);
process (clk)
 begin
	if rst = '1' then
			cnt <= (OTHERS => '0');
		else
       mem_width_read <= conv_integer(memory_width_read);
		bit_counter_reg <= bit_counter;
		if ( bit_counter / 16  = 0) then
			cnt <= cnt + "000001";
			addr_mem <= addr_mem + '1';
			bit_counter <= mem_width_read + bit_counter - 16;
		else
			bit_counter <= bit_counter - 16;
		end if;
		if (cnt > 0) then
			if (bit_counter_reg = 0) then
				slash_reg_data( (mem_width_read_max_val - 1) downto 0) <= reg_data_mem( (mem_width_read_max_val - 1) downto 0);
			elsif (bit_counter_reg <= 16) then
				slash_reg_data <= prepare_bit_vector(reg_data_mem, slash_reg_data, bit_counter_reg);
			else
				slash_reg_data( ((mem_width_read_max_val*2)-16) DOWNTO 0 ) <= slash_reg_data( (mem_width_read_max_val*2) DOWNTO 16 );
			end if;
		end if;
	end if;
end if;
 end process;
end rtl;
testbench
library IEEE;
--use IEEE.STD_LOGIC_ARITH.ALL;
use ieee.numeric_std.all;
ENTITY xxx_vhd_tst IS
END xxx_vhd_tst;
ARCHITECTURE xxx_arch OF xxx_vhd_tst IS
-- constants
-- signals
SIGNAL clk : STD_LOGIC;
SIGNAL memory_width_read  :  std_logic_vector (6 downto 0);
SIGNAL data_out : STD_LOGIC_VECTOR(15 DOWNTO 0);
SIGNAL din : STD_LOGIC_VECTOR(127 DOWNTO 0);
SIGNAL rst : STD_LOGIC;
SIGNAL we : STD_LOGIC;
COMPONENT xxx
PORT (
clk : IN STD_LOGIC;
memory_width_read  : in std_logic_vector (6 downto 0);
data_out : OUT STD_LOGIC_VECTOR(15 DOWNTO 0);
din : IN STD_LOGIC_VECTOR(127 DOWNTO 0);
rst : IN STD_LOGIC;
we : IN STD_LOGIC
END COMPONENT;
BEGIN
i1 : xxx
PORT MAP (
-- list connections between master ports and signals
clk => clk,
memory_width_read => memory_width_read,
data_out => data_out,
din => din,
rst => rst,
we => we
clk_gen: process
begin
clk <= '1';
wait for 2.5 ns;
clk <= '0';
wait for 2.5 ns;
end process;
rst_gen: process
begin
rst <= '1';
wait for 5 ns;
rst <= '0';
wait;
end process;
din <= (OTHERS => '0');
we <= '0';
memory_width_read <= std_logic_vector(to_unsigned(57, memory_width_read'length)); --57 bit
END xxx_arch;
Можно же просто двухпортовую память сделать. С разной шириной шины на запись и чтение.
попробуйте сделать 57, 18 или 112 бит в 16 бит
Я пробовал когда-то давно, ничего не получилось, там есть ограничения по разрядностям вход/выход и их соотношению
То есть память получается на регистрах?
блочная.
там так сказать конвеер организован который делает из N бит, которые прочитались из памяти раскладывает по 16 бит.
Для понимания просимулируйте и все увидите... :)
во вложении - do файлы для моделсима
do_files.zip
