Хочу попробовать запустить spi slave на циклоне. Поискал в сети готовые исходники, примеров много для этого интерфейса не знаю с какого начать, подскажите пожалуйста ссылку на проверенный пример, который вам понравился ))
`timescale 1ns/1ns
`define CLOCK_PHASE 0
`define CLOCK_POLARITY 0
module spi_slave #(
  parameter  SHIFT_DIRECTION = 0,
  parameter  DATA_LENGTH	 = 8		//  changed from 32 to 8
  //Back end device interfacet
  CSn,
  DATA_IN,	//8 bit width - changed from 32 bits
  WR_RD,
  DATA_OUT,	//8 bit width - changed from 32 bits
  TX_RDY,
  RX_RDY,
  TX_ERR,
  RX_ERR,
  CLK_I,
  RST_I,
  //spi interface
  MISO_SLAVE,
  MOSI_SLAVE,
  CSn_SLAVE,
  SCLK_SLAVE
  //back end device interface
  input			   CSn;
  input [7:0]		 DATA_IN;		//8 bit width - changed from 32 bits
  input			   WR_RD;
  output [7:0]		DATA_OUT;		//8 bit width - changed from 32 bits
  output			  TX_RDY;
  output			  RX_RDY;
  output			  TX_ERR;
  output			  RX_ERR;
  input			   CLK_I;
  input			   RST_I;
  //spi interface
  output			  MISO_SLAVE;
  input			   MOSI_SLAVE;
  input			   CSn_SLAVE;
  input			   SCLK_SLAVE;
  parameter		   UDLY		  = 1;
  //register access
  reg					 MISO_SLAVE;
  reg [7:0]			   latch_s_data;		//8 bit width - changed from 32 bits
  reg [DATA_LENGTH-1:0]   reg_rxdata;
  reg [DATA_LENGTH-1:0]   reg_txdata;
  reg [DATA_LENGTH-1:0]   rx_shift_data;
  reg					 reg_toe;
  reg					 reg_roe;
  reg					 reg_trdy;
  reg					 reg_rrdy;
  reg					 tx_done;
  reg					 rx_done;
  reg					 rx_done_flip1;
  reg					 rx_done_flip2;
  reg					 rx_done_flip3;
  reg					 tx_done_flip1;
  reg					 tx_done_flip2;
  reg					 tx_done_flip3;
  reg  [5:0]			  rx_data_cnt;
  reg  [5:0]			  tx_data_cnt;
  assign  TX_RDY=reg_trdy;
  assign  RX_RDY=reg_rrdy;
  assign  TX_ERR=reg_toe;
  assign  RX_ERR=reg_roe;
  assign  DATA_OUT=reg_rxdata;
  always @(posedge CLK_I or posedge RST_I)
 if(RST_I)
   latch_s_data  <= #UDLY 32'h0;
 else if (!WR_RD && !CSn && reg_trdy)
   latch_s_data  <= #UDLY DATA_IN;
//Receive Data Register
 if(RST_I)
   reg_rxdata			<= #UDLY 'h0;
 else if (rx_done_flip1 && !rx_done_flip2)
   reg_rxdata			<= #UDLY rx_shift_data;
//Transmit Data Register
 if(RST_I)
   reg_txdata			   <= #UDLY 'h0;
 else //if (!WR_RD && !CSn && reg_trdy)
   reg_txdata			   <= #UDLY latch_s_data;
//-----------------------------For Rx data,
//-----------------sample at posedge when CLOCK_POLARITY=0 and CLOCK_PHASE is 0
  `ifdef CLOCK_POLARITY
	 `ifdef CLOCK_PHASE
	   always @(posedge SCLK_SLAVE or posedge RST_I)
		 if (RST_I)
		   rx_shift_data	 <= #UDLY 'h0;
		 else if (!CSn_SLAVE)
			 if (SHIFT_DIRECTION)
				rx_shift_data   <= #UDLY {MOSI_SLAVE,rx_shift_data[DATA_LENGTH-1:1]};
			 else
				rx_shift_data   <= #UDLY {rx_shift_data,MOSI_SLAVE};
		 if (RST_I)
			rx_data_cnt	 <= #UDLY 'h0;
		 else if (rx_data_cnt == DATA_LENGTH - 1)
			rx_data_cnt	 <= #UDLY rx_data_cnt + 1;
		 if (RST_I)
			rx_done		 <= #UDLY 1'b0;
			rx_done		 <= #UDLY 1'b1;
		 else
	 //-----------------sample at negedge when CLOCK_POLARITY=0 and CLOCK_PHASE is 1
	 `else
	  //For Rx data, sample at negedge when CLOCK_PHASE is 1
	  always @(negedge SCLK_SLAVE or posedge RST_I)
		 if (RST_I)
			 else
		 if (RST_I)
		 if (RST_I)
		 else
	   //end
	 `endif
  //-----------------sample at negedge when CLOCK_POLARITY=1 and CLOCK_PHASE is 0
  `else
	   `ifdef CLOCK_PHASE
		 if (RST_I)
			 else
		 if (RST_I)
		 if (RST_I)
		 else
	 //-----------------sample at posedge when CLOCK_POLARITY=1 and CLOCK_PHASE is 1
	 `else
		 if (RST_I)
			 else
		 if (RST_I)
		 if (RST_I)
		 else
	   //end
	 `endif
  `endif
 if (RST_I) begin
   rx_done_flip1				<= #UDLY 1'b0;
   rx_done_flip2				<= #UDLY 1'b0;
   rx_done_flip3				<= #UDLY 1'b0;
 end
 else begin
   rx_done_flip1				<= #UDLY rx_done;
   rx_done_flip2				<= #UDLY rx_done_flip1;
   rx_done_flip3				<= #UDLY rx_done_flip2;
 end
 if (RST_I)
   reg_rrdy					 <= #UDLY 1'b0;
 else if (rx_done_flip2 && !rx_done_flip3)
   reg_rrdy					 <= #UDLY 1'b1;
 else if (WR_RD && !CSn)
 if (RST_I)
   reg_roe					  <= #UDLY 1'b0;
 else if (rx_done_flip2 && !rx_done_flip3 && reg_rrdy)
   reg_roe					  <= #UDLY 1'b1;
//--------------------For Tx data,
  //-----------------------------------update at negedge when CLOCK_POLARITY=0 and CLOCK_PHASE is 0
	   `ifdef CLOCK_PHASE
		 //always @(*)
		 always @(reg_txdata or tx_data_cnt or CSn_SLAVE )
		   if (!CSn_SLAVE)
			 MISO_SLAVE   <= #UDLY SHIFT_DIRECTION ? reg_txdata[tx_data_cnt] :
											 reg_txdata[DATA_LENGTH-tx_data_cnt-1];
		   else
			 MISO_SLAVE<=1'bz;
		   if (RST_I)
			  tx_data_cnt	 <= #UDLY 'h0;
		   else if (tx_data_cnt == DATA_LENGTH - 1)
			  tx_data_cnt	 <= #UDLY tx_data_cnt + 1;
		   if (RST_I)
			  tx_done	 <= #UDLY 1'b0;
			  tx_done	 <= #UDLY 1'b1;
		   else
	   //-----------------------------------update at posedge when CLOCK_POLARITY=0 and CLOCK_PHASE is 1
	   `else
		 //always @(posedge SCLK_SLAVE or posedge RST_I)
		 //  if (RST_I)
		 //	MISO_SLAVE   <= #UDLY 1'b0;
		 //  else
		 //	MISO_SLAVE   <= #UDLY SHIFT_DIRECTION ? reg_txdata[tx_data_cnt] :
		 //											reg_txdata[DATA_LENGTH-tx_data_cnt-1];
		 always @(posedge SCLK_SLAVE)
		   if (!CSn_SLAVE)
		   else
			 MISO_SLAVE<=1'bz;
		   if (RST_I)
		   if (RST_I)
		   else
	   `endif
  //-----------------------------------update at posedge when CLOCK_POLARITY=1 and CLOCK_PHASE is 0
  `else
	   `ifdef CLOCK_PHASE
		 //always @(*)
		   if (!CSn_SLAVE)
		   else
			 MISO_SLAVE<=1'bz;
		   if (RST_I)
		   if (RST_I)
		   else
	   //-----------------------------------update at negedge when CLOCK_POLARITY=1 and CLOCK_PHASE is 1
	   `else
		// always @(negedge SCLK_SLAVE or posedge RST_I)
		//   if (RST_I)
		//   else
		 always @(negedge SCLK_SLAVE)
		   if (!CSn_SLAVE)
		   else
			 MISO_SLAVE<=1'bz;
		   if (RST_I)
		   if (RST_I)
		   else
	   `endif
  `endif
 if (RST_I) begin
   tx_done_flip1				<= #UDLY 1'b0;
   tx_done_flip2				<= #UDLY 1'b0;
   tx_done_flip3				<= #UDLY 1'b0;
 end
 else begin
   tx_done_flip1				<= #UDLY tx_done;
   tx_done_flip2				<= #UDLY tx_done_flip1;
   tx_done_flip3				<= #UDLY tx_done_flip2;
 end
 if (RST_I)
	reg_trdy	 <= #UDLY 1'b1;
 else if (!WR_RD && !CSn)
	reg_trdy	 <= #UDLY 1'b0;
 else if (tx_done_flip2 && !tx_done_flip3)
 if(RST_I)
   reg_toe	  <= #UDLY 1'b0;
 else if(!reg_trdy && !WR_RD && !CSn)
   reg_toe	  <= #UDLY 1'b1;
 else if(!WR_RD && !CSn)
endmodule
тестбенч:
`timescale 1ns/1ps
module spi_speripheral_tb;
wire  clk,rst;
wire  mosi,csn_spi,sclk;
wire  csn,wr_rd;
wire  [7:0] data_out;
wire miso;
wire tx_rdy,rx_rdy,tx_err,rx_err;
wire [7:0] data_in;
spi_master spi_master(
 .sclk_master(sclk),
 .csn_master(csn_spi),
 .mosi_master(mosi),
 .miso_master(miso)
spi_slave spi_slave
  //slave port
  .CSn(csn),
  .DATA_IN(data_in),	//8 bit width - changed from 32 bits
  .WR_RD(wr_rd),
  .DATA_OUT(data_out),	//8 bit width - changed from 32 bits
  .TX_RDY(tx_rdy),
  .RX_RDY(rx_rdy),
  .TX_ERR(tx_err),
  .RX_ERR(rx_err),
  //spi interface
  .MISO_SLAVE(miso),
  .MOSI_SLAVE(mosi),
  .CSn_SLAVE(csn_spi),
  .SCLK_SLAVE(sclk),
  //system clock and reset
  .CLK_I(clk),
  .RST_I(rst)
back_end_device back_end_device(
 .CSn(csn),
 .DATA_IN(data_out),
 .WR_RD(wr_rd),
 .DATA_OUT(data_in),
 .TX_RDY(tx_rdy),
 .RX_RDY(rx_rdy),
 .TX_ERR(tx_err),
 .RX_ERR(rx_err),
 .CLK(clk),
 .RST(rst)
endmodule
`timescale 1ns/1ps
module spi_master(
 sclk_master,
 csn_master,
 mosi_master,
 miso_master
parameter  CLOCK_PHASE	 = 0;
parameter  CLOCK_POLARITY  = 0;
parameter  sclk_cycle= 40;
parameter  SHIFT_DIRECTION = 0;
parameter  DATA_LENGTH	 = 8;		//  changed from 32 to 8
output sclk_master;
output csn_master;
output mosi_master;
input  miso_master;
reg sclk_master;
reg csn_master;
reg mosi_master;
reg [7:0] master_data_in;
reg [7:0] master_data_out;
reg [2:0] cnt;
initial begin
 if(CLOCK_POLARITY)
sclk_master<=#1 1'b1;
 else
sclk_master<=#1 1'b0;
 csn_master<=1'b1;
 master_data_in<=8'h00;
 master_data_out<=8'h00;
 cnt<=3'h0;
 mosi_master<=1'b0;
 #306;
 spi_master_operation(8'h73);
 #100;
 spi_master_operation(8'h43);
 #104;
 spi_master_operation(8'h19);
 #100
 spi_master_operation(8'h55);
 #100
 spi_master_operation(8'haa);
 #100
 $stop;
end
task spi_master_operation;
input   [7:0]   data_out;
integer  i;
begin
$display($time,"ns: SPI master sends data %h",data_out);
master_data_out=data_out;
csn_master<=1'b0;
if(!CLOCK_POLARITY) begin
  if(!CLOCK_PHASE) begin
	 cnt<=3'h0;
	 for (i = 7; i >= 0; i = i - 1) begin
	   mosi_master<=SHIFT_DIRECTION ? master_data_out[cnt]:master_data_out[DATA_LENGTH-cnt-1];
	   #sclk_cycle;
	   master_data_in<={master_data_in[6:0],miso_master};
	   #sclk_cycle;
	   sclk_master<=#1 1'b0;	// at the falling edge of SCLK.
	   cnt=cnt+1;
	 end
	 #2;
	 csn_master<=1'b1;
  end
  else begin
	 cnt<=3'h0;
	   #sclk_cycle;
	   sclk_master<=1'b1;  // at the raising edge of SCLK.
	   cnt<=cnt+1;
	   #sclk_cycle;
	   sclk_master<=1'b0;
	 end
	 #2;
	 csn_master<=1'b1;
  end
end
else begin
	 cnt<=3'h0;
	   #sclk_cycle;
	   sclk_master<=1'b0;
	   #sclk_cycle;
	   cnt=cnt+1;
	 end
	 #2;
	 csn_master<=1'b1;
  end
  else begin
	 cnt<=3'h0;
	   #sclk_cycle;
	   sclk_master<=1'b0;  // at the falling edge of SCLK.
	   cnt<=cnt+1;
	   #sclk_cycle;
	   sclk_master<=1'b1;
	 end
	 #2;
	 csn_master<=1'b1;
  end
end
$display($time,"ns: SPI master receive data %h",master_data_in);
end
endtask
endmodule
`timescale 1ns/1ps
module back_end_device(
 CSn,
 DATA_IN,
 WR_RD,
 DATA_OUT,
 TX_RDY,
 RX_RDY,
 TX_ERR,
 RX_ERR,
 CLK,
 RST
output CLK;
output RST;
output CSn;
output WR_RD;
input  TX_RDY;
input  RX_RDY;
input  TX_ERR;
input  RX_ERR;
parameter  clk_cycle= 10;
reg CLK;
reg RST;
reg CSn;
reg WR_RD;
reg [7:0] DATA_OUT;
integer i;
always #(clk_cycle/2) CLK = ~CLK;
initial begin
 RST<=1'b0;
 CLK<= 1'b0;
 CSn<=1'b1;
 WR_RD<=1'b1;
 DATA_OUT<=8'h00;
 i=0;
 #2;
 RST<=1'b1;
 #200;
 RST<=1'b0;
  while(i<3) begin
  @(posedge CLK)
 if(RX_RDY || TX_RDY) begin
	 if(TX_RDY) begin
		 CSn<=#1 1'b0;
		 WR_RD<=#1 1'b0;
		 DATA_OUT=#1 $random % 60;
		 i=i+1;
		 $display($time,"ns: Back end device send data %h",DATA_OUT);
		 @(posedge CLK)
		  CSn<=#1 1'b1;
		  WR_RD<=#1 1'b1;
	 end
	 else if(RX_RDY) begin
		  CSn<=#1 1'b0;
		  WR_RD<=#1 1'b1;
		  $display($time,"ns: Back end device receive data %h",DATA_IN);
		  @(posedge CLK)
		   CSn<=#1 1'b1;
		   WR_RD<=#1 1'b1;
	 end
 end
  end
  @(posedge CLK)
		 CSn<=#1 1'b0;
		 WR_RD<=#1 1'b0;
		 @(posedge CLK)
		  CSn<=#1 1'b1;
		  WR_RD<=#1 1'b1;
end
endmodule
//--------------------------------EOF-----------------------------------------
module BI_DIR (O,I0,IO,OE);
input I0,OE;
inout IO;
output O;
supply0 GND;
supply1 VCC;
reg IO0, O0;
wire IO1;
parameter PULL = "Off";
parameter OUTOPEN = "Off";
//assign O=O0;
buf INSXQ1 (O,O0);
//assign IO = IO0;
//buf INSXQ2 (IO,IO0);
//assign IO1 = IO;
buf INSXQ3 (IO1,IO);
bufif1 INSXQ2 (IO,IO0,OE);
always @(IO1)
begin
if (PULL == "Off")
	case(IO1)
	   1'b0: O0 = 1'b0;
	   1'b1: O0 = 1'b1;
	   1'bz: O0 = 1'bx;
	   1'bx: O0 = 1'bx;
	endcase
else if (PULL == "Up")
	case(IO1)
	   1'b0: O0 = 1'b0;
	   1'b1: O0 = 1'b1;
	   1'bz: O0 = 1'b1;
	endcase
else if (PULL == "Down")
	case(IO1)
	   1'b0: O0 = 1'b0;
	   1'b1: O0 = 1'b1;
	   1'bz: O0 = 1'b0;
	endcase
else if (PULL == "Hold")
	case(IO1)
	   1'b0: O0 = 1'b0;
	   1'b1: O0 = 1'b1;
	   1'bz: O0 = O0;
	endcase
end
always @(OE or I0)
 begin
 if (OE == 1'b0)
	 IO0 = 1'bz;
 else if (OE == 1'b1)
		if (OUTOPEN == "Off")
		   case(I0)
			 1'b0: IO0 = 1'b0;
			 1'b1: IO0 = 1'b1;
			 1'bz: IO0 = 1'bx;
			 1'bx: IO0 = 1'bx;
		   endcase
		else if (OUTOPEN == "Drain" || OUTOPEN == "Collect")
		   begin
			 if (I0 == 1'b0)
				IO0 = 1'b0;
			 else if (I0 == 1'b1)
			   begin
				 if (PULL == "Off")
				   IO0 = 1'bz;
				   IO0 = 1'b1;
				   IO0 = 1'b0;
				   IO0 = IO0;
				 else
				   IO0 = 1'bz;
			   end
			 else
				IO0 = 1'bx;
	  end
 end
specify
(I0 => IO) = 0:0:0, 0:0:0;
(OE => IO) = 0:0:0, 0:0:0;
(IO => O) =  0:0:0, 0:0:0;
endspecify
endmodule
PS могу поделиться описанием на VHDL...
Благодарю за код, давайте если не жалко )).
Есть какие отличия ? На верилоге вроде компактнее получается код, конечно у меня опыта не много поэтому утверждать не буду.
Сейчас попробую протестировать на stm32f407 ep3c5e результат напишу.
Значок решетка что означает? Немного не по теме, случайно не знаете в квартусе 13,1 есть автоформатирование кода ?
описание на VHDL - функциональных отличий нет по сравнению с описанием на verilog.
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity spi_slave is
generic (DATA_LENGTH : integer:=8;
		 SHIFT_DIRECTION: std_logic := '0';
		 CLOCK_POLARITY:std_logic:='0';
		 CLOCK_PHASE:std_logic:='0');
 port (
	CSn	   : in  std_logic;
	DATA_IN   : in  std_logic_vector(7 downto 0);
	WR_RD	 : in  std_logic;
	DATA_OUT  : out  std_logic_vector(7 downto 0);
	TX_RDY	 : out  std_logic;
	RX_RDY	 : out  std_logic;
	TX_ERR	  : out std_logic;
	RX_ERR	  : out std_logic;
	CLK_I	 : in std_logic;
	RST_I	 : in  std_logic;
	MISO_SLAVE  : out std_logic;
	MOSI_SLAVE  : in  std_logic;
	CSn_SLAVE   : in std_logic;
	SCLK_SLAVE   : in std_logic
end;
architecture arch of spi_slave is
constant UDLY:time:=1 ns;
signal	latch_s_data:std_logic_vector(7 downto 0);
 signal	reg_rxdata:std_logic_vector(DATA_LENGTH-1 downto 0);
 signal	reg_txdata:std_logic_vector(DATA_LENGTH-1 downto 0);
 signal	rx_shift_data:std_logic_vector(DATA_LENGTH-1 downto 0);
 signal					 reg_toe:std_logic;
 signal					 reg_roe:std_logic;
 signal					 reg_trdy:std_logic;
 signal					 reg_rrdy:std_logic;
 signal					 tx_done:std_logic;
 signal					 rx_done:std_logic;
 signal					 rx_done_flip1:std_logic;
 signal					 rx_done_flip2:std_logic;
 signal					 rx_done_flip3:std_logic;
 signal					 tx_done_flip1:std_logic;
 signal					 tx_done_flip2:std_logic;
 signal					 tx_done_flip3:std_logic;
 signal				rx_data_cnt:std_logic_vector(5 downto 0);
 signal				tx_data_cnt:std_logic_vector(5 downto 0);
begin
	TX_RDY<=reg_trdy;
RX_RDY<=reg_rrdy;
TX_ERR<=reg_toe;
RX_ERR<=reg_roe;
DATA_OUT<=reg_rxdata;
process(CLK_I,RST_I) begin
 if(RST_I='1') then
   latch_s_data  <= (others => '0');
 elsif rising_edge(CLK_I) then
   if (WR_RD='0' and CSn='0' and reg_trdy='1') then
	 latch_s_data  <=DATA_IN;
   end if;
 end if;
end process;
--Receive Data Register
 if(RST_I='1') then
   reg_rxdata			<=(others => '0');
   if (rx_done_flip1='1' and rx_done_flip2='0') then
	 reg_rxdata			<= rx_shift_data;
   end if;
 end if;
  end process;
--Transmit Data Register
 if(RST_I='1') then
   reg_txdata			   <= (others => '0');
   reg_txdata			   <= latch_s_data;
 end if;
  end process;
  -------------------------------For Rx data,
-------------------sample at posedge when CLOCK_POLARITY=0 and CLOCK_PHASE is 0
  u1: if CLOCK_POLARITY='0' and CLOCK_PHASE='0' generate
	  process(SCLK_SLAVE,RST_I) begin
		if (RST_I='1') then
		  rx_shift_data	 <= (others => '0');
		elsif rising_edge(SCLK_SLAVE) then
		 if (CSn_SLAVE='0') then
			if (SHIFT_DIRECTION='1') then
			   rx_shift_data   <= MOSI_SLAVE & rx_shift_data(DATA_LENGTH-1 downto 1);
			else
			   rx_shift_data   <= rx_shift_data(DATA_LENGTH-2 downto 0) & MOSI_SLAVE;
			end if;
		 end if;
		end if;
	  end process;
	  process(SCLK_SLAVE ,RST_I) begin
		if (RST_I='1') then
		   rx_data_cnt	 <= (others => '0');
		  if (rx_data_cnt = DATA_LENGTH - 1) then
			rx_data_cnt	 <=(others => '0');
		  elsif (CSn_SLAVE='0') then
		   rx_data_cnt	 <=rx_data_cnt + 1;
		  end if;
		end if;
	  end process;
		if (RST_I='1') then
		   rx_done		 <= '0';
			rx_done		 <= '1';
		  else
			rx_done		 <= '0';
		  end if;
		end if;
	  end process;
end generate;
	 -------------------sample at negedge when CLOCK_POLARITY=0 and CLOCK_PHASE is 1
u2: if CLOCK_POLARITY='0' and CLOCK_PHASE='1' generate
	  --For Rx data, sample at negedge when CLOCK_PHASE is 1
		 if (RST_I='1') then
		 elsif falling_edge(SCLK_SLAVE) then
			 else
			 end if;
		  end if;
		 end if;
	   end process;
		 if (RST_I='1') then
		   end if;
		 end if;
	   end process;
		 if (RST_I='1') then
			rx_done		 <= '0';
			 rx_done		 <= '1';
		   else
			 rx_done		 <= '0';
		   end if;
		 end if;
	   end process;
 end generate;
  -------------------sample at negedge when CLOCK_POLARITY=1 and CLOCK_PHASE is 0
  u3:if CLOCK_POLARITY='1' and CLOCK_PHASE='0' generate
		 if (RST_I='1') then
			 else
			 end if;
		  end if;
		 end if;
	   end process;
		 if (RST_I='1') then
		   end if;
		 end if;
	   end process;
		 if (RST_I='1') then
			rx_done		 <= '0';
			 rx_done		 <= '1';
		   else
			 rx_done		 <= '0';
		   end if;
		 end if;
	   end process;
 end generate;
	 -------------------sample at posedge when CLOCK_POLARITY=1 and CLOCK_PHASE is 1
 u4:	if CLOCK_POLARITY='1' and CLOCK_PHASE='1' generate
		 if (RST_I='1') then
			 else
			 end if;
		  end if;
		 end if;
	   end process;
		 if (RST_I='1') then
		   end if;
		 end if;
	   end process;
		 if (RST_I='1') then
			rx_done		 <= '0';
			 rx_done		 <= '1';
		   else
			 rx_done		 <= '0';
		   end if;
		 end if;
	   end process;
 end generate;
 if (RST_I='1') then
   rx_done_flip1				<= '0';
   rx_done_flip2				<= '0';
   rx_done_flip3				<= '0';
   rx_done_flip1				<= rx_done;
   rx_done_flip2				<= rx_done_flip1;
   rx_done_flip3				<= rx_done_flip2;
 end if;
  end process;
 if (RST_I='1') then
   reg_rrdy					 <= '0';
  if (rx_done_flip2='1' and rx_done_flip3='0') then
	reg_rrdy					 <= '1';
  elsif (WR_RD='1' and CSn='0') then
	reg_rrdy					 <= '0';
  end if;
 end if;
  end process;
 if (RST_I='1') then
   reg_roe					  <= '0';
  if (rx_done_flip2='1' and rx_done_flip3='0' and reg_rrdy='1') then
	reg_roe					  <= '1';
	reg_roe					  <= '0';
  end if;
 end if;
  end process;
----------------------For Tx data,
  -------------------------------------update at negedge when CLOCK_POLARITY=0 and CLOCK_PHASE is 0
u11:  if CLOCK_POLARITY='0' and CLOCK_PHASE='0' generate
		 process(reg_txdata,tx_data_cnt,CSn_SLAVE ) begin
		   	 if(SHIFT_DIRECTION='1') then
				MISO_SLAVE   <= reg_txdata(conv_integer(tx_data_cnt));
			 else
				MISO_SLAVE   <= reg_txdata(conv_integer(DATA_LENGTH-tx_data_cnt-1));
			 end if;
		   else
			 MISO_SLAVE<='Z';
		   end if;
		 end process;
		   if (RST_I='1') then
			  tx_data_cnt	 <= (others => '0');
			 if (tx_data_cnt = DATA_LENGTH - 1) then
			  tx_data_cnt	 <= tx_data_cnt + 1;
			 end if;
		   end if;
		 end process;
		   if (RST_I='1') then
			  tx_done	 <='0';
			  tx_done	 <= '1';
			 else
			  tx_done	 <= '0';
			 end if;
		   end if;
		 end process;
 end generate;
	   -------------------------------------update at posedge when CLOCK_POLARITY=0 and CLOCK_PHASE is 1
  u22:	 if CLOCK_POLARITY='0' and CLOCK_PHASE='1' generate
		 process (SCLK_SLAVE) begin
			   else
			   end if;
			 else
			   MISO_SLAVE<='Z';
			 end if;
		  end if;
		 end process;
		   if (RST_I='1') then
			 end if;
		   end if;
		 end process;
		   if (RST_I='1') then
			  tx_done	 <= '0';
			  tx_done	 <= '1';
			 else
			  tx_done	 <= '0';
			 end if;
		   end if;
		 end process;
 end generate;
  -------------------------------------update at posedge when CLOCK_POLARITY=1 and CLOCK_PHASE is 0
u33:  if CLOCK_POLARITY='1' and CLOCK_PHASE='0' generate
			 else
			 end if;
		   else
			 MISO_SLAVE<='Z';
		   end if;
		 end process;
		   if (RST_I='1') then
			 end if;
		   end if;
		 end process;
		   if (RST_I='1') then
			  tx_done	 <= '0';
			  tx_done	 <= '1';
			 else
			  tx_done	 <= '0';
			 end if;
		   end if;
		 end process;
	  end generate;
	   -------------------------------------update at negedge when CLOCK_POLARITY=1 and CLOCK_PHASE is 1
  u44:	if CLOCK_POLARITY='1' and CLOCK_PHASE='1' generate
		   if falling_edge(CLK_I) then
			   else
			   end if;
			 else
			   MISO_SLAVE<='Z';
			 end if;
		  end if;
		 end process;
		   if (RST_I='1') then
			 end if;
		   end if;
		 end process;
		   if (RST_I='1') then
			  tx_done	 <='0';
			  tx_done	 <= '1';
			 else
			  tx_done	 <= '0';
			 end if;
		   end if;
		 end process;
	 end generate;
 if (RST_I='1') then
   tx_done_flip1				<= '0';
   tx_done_flip2				<= '0';
   tx_done_flip3				<= '0';
   tx_done_flip1				<= tx_done;
   tx_done_flip2				<= tx_done_flip1;
   tx_done_flip3				<= tx_done_flip2;
 end if;
  end process;
 if (RST_I='1') then
   reg_roe					  <= '0';
	reg_roe					  <= '1';
	reg_roe					  <= '0';
  end if;
 end if;
  end process;
 if (RST_I='1') then
	reg_trdy	 <= '1';
  if (WR_RD='0' and CSn='0') then
	reg_trdy	 <= '0';
  elsif (tx_done_flip2='1' and tx_done_flip3='0') then
	reg_trdy	 <= '1';
  end if;
 end if;
  end process;
 if (RST_I='1') then
   reg_toe	  <= '0';
  if(reg_trdy='0' and WR_RD='0' and CSn='0') then
   reg_toe	  <= '1';
  elsif(WR_RD='0' and CSn='0') then
   reg_toe	  <= '0';
  end if;
 end if;
 end process;
end arch;
тестбенч:
library ieee;
entity spi_master is
 port(
	sclk_master: out  std_logic;
  csn_master: out  std_logic;
  mosi_master: out  std_logic;
  miso_master: in  std_logic
end;
architecture arch_spi_master of spi_master is
constant  CLOCK_PHASE:std_logic:='0';
constant  CLOCK_POLARITY:std_logic:='0';
constant  SHIFT_DIRECTION:std_logic:='0';
constant  DATA_LENGTH:integer:= 8;
--signal  master_data_in:std_logic_vector(7 downto 0);
--signal  master_data_out:std_logic_vector(7 downto 0);
--signal cnt:std_logic_vector(2 downto 0);
signal sclk_master_tmp: std_logic;
signal csn_master_tmp:  std_logic;
signal mosi_master_tmp: std_logic;
function slv4_xcha (inp: STD_LOGIC_VECTOR(3 downto 0)) return CHARACTER is
variable result: character;
begin
 case inp is
when "0000" => result := '0';
when "0001" => result := '1';
when "0010" => result := '2';
when "0011" => result := '3';
when "0100" => result := '4';
when "0101" => result := '5';
when "0110" => result := '6';
when "0111" => result := '7';
when "1000" => result := '8';
when "1001" => result := '9';
when "1010" => result := 'a';
when "1011" => result := 'b';
when "1100" => result := 'c';
when "1101" => result := 'd';
when "1110" => result := 'e';
when "1111" => result := 'f';
when others => result := 'x';
 end case;
return result;
end;
function slv8_xstr (inp: STD_LOGIC_VECTOR(7 downto 0)) return STRING is
variable result : string (1 to 2);
begin
 result := slv4_xcha(inp(7 downto 4)) & slv4_xcha(inp(3 downto 0));
 return result;
end;
procedure spi_master_operation (signal sclk_master_tmp : out std_logic;
				  signal csn_master_tmp: out std_logic;
				  signal mosi_master_tmp: out std_logic;
				  signal miso_master: in std_logic;
				  constant data_out:in STD_LOGIC_VECTOR(7 downto 0);
				  constant CLOCK_PHASE : in std_logic;
				  constant CLOCK_POLARITY : in std_logic;
				  constant SHIFT_DIRECTION : in std_logic;
				  constant DATA_LENGTH : in integer
				   ) is
variable master_data_in:std_logic_vector(7 downto 0):=(others => '0');
variable master_data_out:std_logic_vector(7 downto 0):=(others => '0');
variable cnt:integer;
variable  i:integer;
variable  sclk_cycle:time:=40 ns;
begin
  csn_master_tmp<='1';
  mosi_master_tmp<='0';
  report "SPI master sends data " & slv8_xstr(data_out);
master_data_out:=data_out;
csn_master_tmp<='0';
if(CLOCK_POLARITY='0') then
  if(CLOCK_PHASE='0') then
	 cnt:=0;
	 for i in 7 downto 0 loop
			mosi_master_tmp<=master_data_out(cnt);
	   else
		   mosi_master_tmp<=master_data_out(DATA_LENGTH-cnt-1);
	   end if;
	   wait for sclk_cycle;
	   sclk_master_tmp<='1';
	   master_data_in:=(master_data_in(6 downto 0) & miso_master);
	   sclk_master_tmp<='0';
	   cnt:=cnt+1;
	 end loop;
	 wait for 2 ns;
  else
	 cnt:=0;
	   else
	   end if;
	   cnt:=cnt+1;
	 end loop;
	 wait for 2 ns;
  end if;
else
	 cnt:=0;
	   else
	   end if;
	   cnt:=cnt+1;
	 end loop;
	 wait for 2 ns;
  else
	 cnt:=0;
	   else
	   end if;
	   cnt:=cnt+1;
	 end loop;
	 wait for 2 ns;
  end if;
end if;
report "SPI master receive data " & slv8_xstr(master_data_in);
end;
begin
sclk_master<=sclk_master_tmp;
csn_master<=csn_master_tmp;
mosi_master<=mosi_master_tmp;
initial: process begin
--wait for 1 ns;
 if(CLOCK_POLARITY='1') then
sclk_master_tmp<='1' after 1 ns;
 else
 end if;
 wait for 306 ns;
 spi_master_operation(sclk_master_tmp,csn_master_tmp,mosi_master_tmp,miso_master,
				   "01110011",CLOCK_PHASE,CLOCK_POLARITY,SHIFT_DIRECTION,DATA_LENGTH);
 wait for 100 ns;
				   "01000011",CLOCK_PHASE,CLOCK_POLARITY,SHIFT_DIRECTION,DATA_LENGTH);
 wait for 104 ns;
				   "00011001",CLOCK_PHASE,CLOCK_POLARITY,SHIFT_DIRECTION,DATA_LENGTH);
  wait for 100 ns;
				   "01010101",CLOCK_PHASE,CLOCK_POLARITY,SHIFT_DIRECTION,DATA_LENGTH);
  wait for 100 ns;
				   "10101010",CLOCK_PHASE,CLOCK_POLARITY,SHIFT_DIRECTION,DATA_LENGTH);
 wait for 100 ns;
 wait;
end process;
end arch_spi_master;
library ieee;
entity back_end_device is
 port(
	CSn: out  std_logic;
  DATA_IN:in STD_LOGIC_VECTOR(7 downto 0);
  WR_RD: out  std_logic;
  DATA_OUT:out STD_LOGIC_VECTOR(7 downto 0);
  TX_RDY: in  std_logic;
  RX_RDY: in  std_logic;
  TX_ERR: in  std_logic;
  RX_ERR: in  std_logic;
  CLK: out  std_logic;
  RST: out  std_logic
end;
architecture arch_back_end_device of back_end_device is
constant  clk_cycle:time:=5 ns;
signal clk_temp:std_logic;
signal data_out_temp:STD_LOGIC_VECTOR(7 downto 0);
signal i:integer:=0;
function slv4_xcha_r (inp: STD_LOGIC_VECTOR(3 downto 0)) return CHARACTER is
begin
 case inp is
 end case;
return result;
end;
function slv8_xstr_r (inp: STD_LOGIC_VECTOR(7 downto 0)) return STRING is
begin
 result := slv4_xcha_r(inp(7 downto 4)) & slv4_xcha_r(inp(3 downto 0));
 return result;
end;
begin
clk_gen:process
 begin
 	 clk_temp<='0';
 	 wait for clk_cycle;
 	 loop
 	 	 clk_temp<=not clk_temp;
 	 	 wait for clk_cycle;
 	 end loop;
end process;
CLK<=clk_temp;
DATA_OUT<=data_out_temp;
 RST<='0';
 CSn<='1';
 WR_RD<='1';
 data_out_temp<=(others => '0');
 wait for 2 ns;
 RST<='1';
 wait for 202 ns;
 RST<='0';
  while(i<3) loop
  wait until clk_temp'event and clk_temp = '1';
 if(RX_RDY='1' or TX_RDY='1') then
	 if(TX_RDY='1') then
		 CSn<='0' after 1 ns;
		 WR_RD<='0' after 1 ns;
		 if(i=0) then
		   data_out_temp<="00001000" after 1 ns;
		 elsif(i=1) then
		 	 data_out_temp<="11101101" after 1 ns;
		 elsif(i=2) then
		 	 data_out_temp<="11011001" after 1 ns;
		 end if;
		 i<=i+1;
		 wait for 1 ns;
		 report "Back end device send data " & slv8_xstr_r(data_out_temp);
		  CSn<='1' after 1 ns;
		  WR_RD<='1' after 1 ns;
	 elsif(RX_RDY='1') then
		  report "Back end device receive data " & slv8_xstr_r(DATA_IN);
	 end if;
 end if;
  end loop;
  while(i=3) loop
		 data_out_temp<="11100011" after 1 ns;
		 wait for 1 ns;
		  i<=4;
  end loop;
wait for 2500 ns;
--wait;
end process;
end arch_back_end_device;
library ieee;
entity spi_speripheral_tb is
end spi_speripheral_tb;
architecture arch_spi_speripheral_tb of spi_speripheral_tb is
component spi_slave is
--generic (DATA_LENGTH : integer:=8;
--		 SHIFT_DIRECTION: std_logic := '0';
--		 CLOCK_POLARITY:std_logic:='0';
--		 CLOCK_PHASE:std_logic:='0');
 port (
	CSn	   : in  std_logic;
  end component;
  component spi_master is
  	  port(
  end component;
  component back_end_device is
  	 port(
  CSn: out  std_logic;
  DATA_IN: in  std_logic_vector(7 downto 0);
  DATA_OUT: out  std_logic_vector(7 downto 0);
  CLK: out  std_logic;
  RST: out  std_logic
end component;
signal  clk,rst:std_logic;
signal  mosi,csn_spi,sclk:std_logic;
signal  csn,wr_rd:std_logic;
signal  data_out:std_logic_vector(7 downto 0);
signal miso:std_logic;
signal tx_rdy,rx_rdy,tx_err,rx_err:std_logic;
signal data_in:std_logic_vector(7 downto 0);
begin
spi_master_uut: spi_master port map(
 sclk_master=>sclk,
 csn_master=>csn_spi,
 mosi_master=>mosi,
 miso_master=>miso
spi_slave_uut: spi_slave port map
  CSn=>csn,
  DATA_IN=>data_in,
  WR_RD=>wr_rd,
  DATA_OUT=>data_out,
  TX_RDY=>tx_rdy,
  RX_RDY=>rx_rdy,
  TX_ERR=>tx_err,
  RX_ERR=>rx_err,
  MISO_SLAVE=>miso,
  MOSI_SLAVE=>mosi,
  CSn_SLAVE=>csn_spi,
  SCLK_SLAVE=>sclk,
  CLK_I=>clk,
  RST_I=>rst
back_end_device_uut: back_end_device port map(
 CSn=>csn,
 DATA_IN=>data_out,
 WR_RD=>wr_rd,
 DATA_OUT=>data_in,
 TX_RDY=>tx_rdy,
 RX_RDY=>rx_rdy,
 TX_ERR=>tx_err,
 RX_ERR=>rx_err,
 CLK=>clk,
 RST=>rst
end arch_spi_speripheral_tb;
#100; (verilog) = wait for 100 ns; (vhdl)
PS у меня это описание работало в "железе"
PS PS Мне не жалко, в надежде, что когда мне что-то понадобиться, то тоже люди тоже откликнуться и помогут...
Благодарю вас. Эта задержка синтезируется или это только для симулятора?
Понятно. Попробовал сразу все заработало)). Частоту подал на clck_in 200Мгц , правильно ?
spi_slave spi_uc(csn,datain,wr_rd,dataout,tx_rdy,rx_rdy,tx_err,rx_err,CLOCK,RESET,SDOUT_UC,SD
I_UC,CS_UC,SCLCK_UC);
always@(posedge CLOCK )
begin
    if(RESET == 1)
     begin
        rxtxrdwr     <= 8'd0;
        adressreg    <= 8'd0;
         getadres     <= 1'b0;
         csn          <= 1'b1;
       wr_rd        <= 1'b1;
         for(initdatafor = 0; initdatafor < 8'd255;initdatafor = initdatafor + 8'd1)
       begin
         dataINuc[initdatafor]  <= 8'd0;
          dataOUTuc[initdatafor] <= 8'd0;
       end
     end
     else begin
          if(CS_UC == 1)
           begin
               getadres  <= 1'b0;
           end
          if(tx_rdy || rx_rdy) begin
             if(tx_rdy) begin
                 csn<= 1'b0;
                 wr_rd<= 1'b0;
                      rxtxrdwr <= 8'd1;
                      if(getadres == 1)
                      begin
                     datain <= 20;//dataOUTuc[adressreg];
                      end else
                      begin
                          datain <= 8'd0;
                      end
             end
             else if(rx_rdy) begin
                 csn<=  1'b0;
                 wr_rd<=  1'b1;
                      rxtxrdwr <= 8'd2;
                      if(getadres == 0)
                      begin
                          getadres  <= 1'b1;
                            adressreg <= dataout;
                      end else
                      begin
                          dataINuc[adressreg] <= dataout;
                     end
             end
          end else
            begin
                if(rxtxrdwr == 1)begin
                     csn<= 1'b1;
                 wr_rd<= 1'b1;
                     rxtxrdwr <= 8'd0;
                 end else if(rxtxrdwr == 2)begin
                  csn<=  1'b1;
                 wr_rd<=  1'b1;
                     rxtxrdwr <= 8'd0;
                 end
            end
     end
end
Единственное почему то последний байт не доходит например отправляю с плис 20 в мк приходит 10 и тд.
Микроконтроллер вначале пробовал с mems датчиком что бы проверить правильность настройки spi интерфейса в микроконтроллере.
режимы работы SPI в мк и в плис должны совпадать. совпадают?
Для обозначения режимов работы интерфейса SPI принято следующее соглашений:
режим 1 (CPOL = 0, CPHA = 0);
режим 2 (CPOL = 0, CPHA = 1);
режим 3 (CPOL = 1, CPHA = 0);
режим 4 (CPOL = 1, CPHA = 1).
Да совпадают
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE);
    SPI_I2S_DeInit(SPI1);
    SPI_InitTypeDef spi1;
    SPI_StructInit(&spi1);
    spi1.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
    spi1.SPI_Mode = SPI_Mode_Master;
    spi1.SPI_DataSize = SPI_DataSize_8b;
    spi1.SPI_CPOL = SPI_CPOL_Low;
    spi1.SPI_CPHA = SPI_CPHA_1Edge;
    spi1.SPI_NSS =  SPI_NSS_Soft | SPI_NSSInternalSoft_Set;
    spi1.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_32;
    spi1.SPI_FirstBit = SPI_FirstBit_MSB;
    SPI_Init(SPI1, &spi1);
    SPI_Cmd(SPI1, ENABLE);
    SPI_NSSInternalSoftwareConfig(SPI1, SPI_NSSInternalSoft_Set);
Сделал осциллограмму если правильно смотрю из плис уходит 00001010 = 10 а должно быть 00010100.
Дико извиняюсь, я напортачил не правильно настроил, все работает отлично.
нужно было объявить это
`define   CLOCK_PHASE
Это настройки spi в stm32f407
большое спасибо за помощь.))
Где-то читал (или сам сделал выводы :) ), что трюк с #1 в чистом RTL-коде это не самая интуитивная/хорошая практика.
Однако, ребята с opencores в низскоскоростных протоколах очень любят такое делать (например, I2C ).
а что оно дает для синтезатора?
Можно как то синтезировать задержку? Иногда очень нужна, делаю либо сдвигом клока либо внешними цепочками.
Разумеется, ничего :)
Или смысл только в том, что бы видеть в симуляции времянки более красивые и приближенные к реальности (появления значения на выходе триггера) "позже", чем edge клока?
Или есть еще какие-то тонкости? :rolleyes:
А для каких целей вам надо синтезировать задержку?
Вы синхронный дизайн планируете делать?
Зачем Вам задержка, если надо, чтобы у Вас часть проекта сработало через определенное время, используйте счетчик, это идеальный вариант
Изменено пользователем Nepoch
#1 сильно помогает "старой гвардии", привыкшей работать с такими конструкциями, во время симуляции видеть причинно-следственные связи, не заглядывая в код, а догадываясь по названиям сигналов.
тем, кто учился писать RTL без #1 - его наличие/отсутствие не помогает никак, может только сбивает с толку.
