IMNO 0 6 апреля, 2015 Опубликовано 6 апреля, 2015 · Жалоба Здравствуйте! 1. Исправьте пожалуйста, чтобы оно скомпилировалось. 2. Почему нельзя объявить сигналы в теле процедуры? signal C_S: std_logic; signal C_R: std_logic; ---------------------------------------------------------------------------------- -- Company: -- Engineer: -- -- Create Date: 20:36:52 04/05/2015 -- Design Name: -- Module Name: laba_4 - Behavioral -- Project Name: -- Target Devices: -- Tool versions: -- Description: -- -- Dependencies: -- -- Revision: -- Revision 0.01 - File Created -- Additional Comments: -- ---------------------------------------------------------------------------------- library IEEE; use IEEE.STD_LOGIC_1164.ALL; -- Uncomment the following library declaration if using -- arithmetic functions with Signed or Unsigned values --use IEEE.NUMERIC_STD.ALL; -- Uncomment the following library declaration if instantiating -- any Xilinx primitives in this code. --library UNISIM; --use UNISIM.VComponents.all; entity laba_4 is port( J: in std_logic; K: in std_logic; C: in std_logic; Q: out std_logic; not_Q: out std_logic ); end laba_4; architecture Behavioral of laba_4 is -----------------------RS триггер------------------------------- procedure RSTrigger( signal S: in std_logic; signal R: in std_logic; signal Q: out std_logic; signal not_Q: out std_logic ) is begin Q <= not( R or not_Q ); not_Q <= not( S or Q ); end RSTrigger; -----------------------RS триггер------------------------------- -----------------------синхронный RS триггер------------------------------- procedure CRSTrigger( signal S: in std_logic; signal R: in std_logic; signal C: in std_logic; signal Q: out std_logic; signal not_Q: out std_logic ) is begin signal C_S: std_logic; signal C_R: std_logic; C_S <= S and C; C_R <= R and C; RSTrigger( C_S, C_R, Q, not_Q ); end CRSTrigger; -----------------------синхронный RS триггер------------------------------- -----------------------двухступенчатый RS триггер------------------------------- procedure TwoRSTrigger( signal S: in std_logic; signal R: in std_logic; signal C: in std_logic; signal Q: out std_logic; signal not_Q: out std_logic ) is begin signal not_Q_S: std_logic; signal Q_R: std_logic; if( C = '1' ) then CRSTrigger( S, R, C, Q, not_Q ); not_Q_S <= not_Q; Q_R <= Q; else CRSTrigger( not_Q_S, Q_R, C, Q, not_Q ); end if; end TwoRSTrigger; -----------------------двухступенчатый RS триггер------------------------------- -----------------------JK триггер------------------------------- procedure JKTrigger( signal J: in std_logic; signal K: in std_logic; signal C: in std_logic; signal Q: out std_logic; signal not_Q: out std_logic ) is begin signal not_Q_J: std_logic; signal Q_K: std_logic; not_Q_J <= J and not_Q; Q_K <= K and Q; TwoRSTrigger( not_Q_J, Q_K, C, Q, not_Q ); end JKTrigger; -----------------------JK триггер------------------------------- begin JKTrigger( J, K, C, Q, not_Q ); end Behavioral; Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Maverick_ 15 6 апреля, 2015 Опубликовано 6 апреля, 2015 · Жалоба Здравствуйте! Описание портов: CLK − вход тактовой частоты; Reset – вход асинхронного сброса; J – J-вход; K – K-вход; Q – выход. library IEEE; use IEEE.std_logic_1164.all; entity JK_tr is port (J: in STD_LOGIC; K:in STD_LOGIC; CLK:in STD_LOGIC; Reset: in STD_LOGIC; Q: out STD_LOGIC); end JK_tr; architecture JK_tr of JK_tr is begin process(clk, reset) is variable Qint: STD_LOGIC; begin if (reset ='0') then Qint:='0'; elsif (CLK'event and CLK ='1') then if (J='1' and K='1') then Qint := not(Qint); elsif (J='0' and K='0') then Qint:=Qint; elsif (J='1' and K='0') then Qint:='1'; elsif (J='0' and K='1') then Qint:='0'; end if; end if; Q<=Qint; end process; end JK_tr; Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Kuzmi4 0 6 апреля, 2015 Опубликовано 6 апреля, 2015 · Жалоба 2 Maverick вот так, по вашей вине, ещё один не научился пользоваться гуглом... Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
